Author Topic: GM 90 6/1  (Read 4721 times)
vegomatic
GM 90 6/1
« on: April 03, 2011, 04:52:23 PM »
need head gaskets for my machine. bought mine from Mike back in the day but it seems that he is out thanks  dermadale@msn.com
Spark_Chaser
    • Web Page
Re: GM 90 6/1 gaskets
« Reply #1 on: April 09, 2011, 02:42:24 PM »
vegomatic,
Were you able to locate a gasket?
My GM-90 is disassembled in storage (2004 batch from Mike M) with a complete gasket kit slated for its rebuild.
If a gasket maker needed a GM-90 head gasket for a pattern I could probably supply it.
I was unaware the standard CS listeroid gasket wouldn't fit.
Spark_Chaser
Spark_Chaser
6/1 GM90 disassembled and in work
past
5KW ST sold
Northern Lights 7KW sold
vegomatic
Re: GM 90 6/1
« Reply #2 on: April 18, 2011, 08:25:54 PM »
Gaskets to go has some but is in the US on holiday till May Are we the only ones who have Gm 90's?  I tried Central Maine  but they are too big
Spark_Chaser
    • Web Page
Re: GM 90 6/1 gasket scan
« Reply #3 on: April 22, 2011, 04:46:05 AM »
I emailed you a scan of the spare head gasket that Mike M sent with my engine.
(Thought I could post it here but am at a loss on how to.)
The measurements are 7" x 6 3/4".  It is stamped 5/1.  I thought it was a standard CS type.
Printing on a standard 8.5 x 11 (in) paper should return an close to original size.  How does it compare to your gasket?
We just relocated our storage unit and my disassembled GM90 is in a cargo van in my driveway.  I'll pull out the head this weekend to see if I actually have the correct gasket.
Been thinking this forum might have room for a GM90 section.
Spark_Chaser
past
5KW ST sold
Spark_Chaser
    • Web Page
Re: GM 90 6/1
« Reply #4 on: April 23, 2011, 11:20:03 PM »
Added a Spark_Chaser gallery on the www.listergallery.com site.
Picture one is my head with what I believe to be a STD CS gasket in place.
The gasket was a spare with the engine that was damaged.
Spark_Chaser
past
5KW ST sold
Re: GM 90 6/1
« Reply #5 on: April 24, 2011, 03:23:03 AM »
4-stud head and gasket for GM90 is not standard CS. Actually I believe 7-stud is the norm for 6/1 and 8/1 CS and they are indeed larger.
Spark_Chaser
    • Web Page
Re: GM 90 6/1
« Reply #6 on: April 24, 2011, 04:24:23 AM »
Wow I never paid that close attention to the differences before.
On the STD CS types do the seven studs go all the way through the cylinder?
Spark_Chaser
past
5KW ST sold
Re: GM 90 6/1
« Reply #7 on: April 24, 2011, 02:51:07 PM »
4 studs go through to the block, 3 to the cylinder casting.
