hello again, how is everyone,
i am looking for a pdf format for a sr1 lister generator, for a friend, the lister number is 5247sr1a20 with a kohler electric plant mod. 3.5 cm 021 63625a, ser. 333937, also have a q. about the high pressure fuel pump/ throttle rack, the pump has been cleaned but the throttle rod that slids back and forth (were the governer hooks to) is a little hard to push/pull through, should this be easy or is it like that normally, and also i need to be reminded, is the fuel pump pressure is 6 to 8 p.s.i ?,
thank you in advance for any help,
trowel
