Author Topic: re-visiting the cast iron radiator cooling for the 6/1  (Read 11833 times)
johna
Re: re-visiting the cast iron radiator cooling for the 6/1
« Reply #15 on: April 23, 2011, 08:08:00 AM »
br549
Thanks for the welcome.  So how does your creation work?  Is there enough air circulation without a fan?
John
Geno
« Reply #16 on: April 23, 2011, 11:51:39 AM »
I’ve refurbished several of the cast iron rads. All of them had lots of scale/rust buildup in them. If you fill them with hot water and radiator cleaner you can get a lot of crud out. If you build a right angle tip for a pressure washer you can get up inside the sections. Be warned though, a right angle tip can be dangerous to use and will jump out of your hands easily.
Thanks, Geno
contaucreek
« Reply #17 on: April 23, 2011, 08:51:40 PM »
Can you use veggie oil as the coolant and then draw it as your fuel ??
bschwartz
« Reply #18 on: April 23, 2011, 09:49:15 PM »
I think the engine would overheat as VO won't transfer the heat away from the engine nearly fast enough.  Maybe if you had a hefty circulating pump, and a MASSIVE radiator.........
-Brett
