Spill timing 14 degrees BTDC is a little retarded. 19-20 BTDC is the norm, but it also can be a little tricky to measure. 19 degrees of spill timing actually equates to an injector firing around 1 degree BTDC, so if your 14 degrees is accurate, your injector is firing well after TDC... With timing that retarded, it shouldn't be knocking. I would first look at mechanical interferences as suggested. To add to the list, check your GIB keys. A loose flywheel can sound like knock as the crankshaft decelerates under compression and accelerates under combustion...
The 6/1 is rated at around I believe 4.4KW. That rating can be misleading. That is 4.4KW of mechanical energy at the engne. With drive and generator losses this equates to around 3.5KW of electrical load on the driven genset, which you discovered is about the max your engine can sustain...
