Hello CD,
My considered opinion, oil filtration comes down to economics and time. Large systems, ships etc, are automated and continuous, use waste heat and auxiliary power to run them. Small applications take a lot of throughput to recover time, money and energy cost. An old Lister does not hold that much oil, and 300 or 400 hours is ok on continuous run with modern oils. Most users forget the bit in the book which suggests a washout of the sump each 1000 hours or so. Bog roll filters and centrifuge gunk still must be disposed of. Spent a lot of time and energy reheating used oil and running thru a serious ex powerstation centrifuge, but it takes long hours and hard to remove carbon at the sub-micron level, so oil still looks black. Hope other members have some easy solutions, Regards, Combustor.
