OK, the 8 is the winter project. Well, the couple of week project. I have an 8/1 CS. It runs. Seems to be in good condition.
1) How many use an oil filter on these engines? Link to the kit?
2) Fuel filter? Is it necessary? What are you guys using? I have a Caterpillar fuel filter head. It has TONS of capacity. Will this work as a flow through filter? Meaning enough suction from the injector pump to pull through it. I will mount the tank higher than pump obviously.
3) I have a donnelson air filter. Also tons big enough for the application.
4) Exhaust... well, seems simple enough. Do you guys step up on pipe size if running for over a couple of feet?
5) Cooling.... well, I have a 12v pump and could run that off an alt into a radiator if needed. I also was thinking of the thermo siphon method. Easier, simpler. Is it totally effective for an 8/1 putting out 4 kw ish? I want to start it, run it, come back 8 hours later and fuel it.
6) Hour meter. Is anyone using one? If so, what? Link? I'd like to actually monitor hours. Not just guess ish.
Thanks
Wags
