I'm not terribly well-versed in the electrical arts, but I have a pretty good idea of what I would like to implement. I'm sure that there exist solutions for what I'm describing, but I'm hoping that what I want exists in an inexpensive package instead of as a sub-set of features to some other, larger and more expensive system which I don't need.
Here's the problem: if for some reason my diesel motive plant (12/2) fails, then I will experience a situation where the flywheels and generator slowly spin down to a stop. During this spin down, voltage drops in a curve over time, which is VERY unfriendly to most equipment that I'm familiar with and tends to fry things in unexpected ways. I'd like to have a system downstream from my generator that just chops off my output voltage and keeps it off in the event of some upstream problem (generator, motor, wiring, etc.) "100% no power" is better than "sort-of no power."
Think of this as a transfer switch that doesn't transfer. Does such a thing exist as a 1/2 transfer switch? If so, who makes them? Or should I just buy a transfer switch? Does anyone have a website or pointers for a vendor for either direction? While I appreciate technical descriptions, I expect that I won't probably build this myself and will end up buying it. I know what I'm good at, and there are too many strange variables in electrical systems for me to say that I'll become an expert at the cost of my computers, televisions, refrigerators, or life.
Here are some possible solutions. Most of them are probably flat out wrong, but I'll take comments on what would work if anyone knows of a product or method that is along these lines:
- a power conditioner. Not only would this provide a more clean power output from the genset, but perhaps it would just drop to zero volts if it was unable to provide it's rated output. The downside is that these things suck quite a bit of power (not sure how much, but I recall at least 20% from my days spent with computing gear that used them.)
- a voltage-detecting breaker. I don't know if this exists. If voltage moves between 0 and 110vac and stays up for more than X seconds, then the breaker "sets" itself. If after that time, input voltage input drops below 110vac for more than X seconds, then the breaker trips and requires that voltage drops to 0 for X seconds before resetting. (Of course, 110vac might be 120vac, or some other value.)
JT
