Author Topic: Start-o-matic flywheel weight  (Read 18788 times)
Veggiefuel
  • Energy Machines Ltd.
« on: November 15, 2010, 04:11:29 AM »
Anyone know the weight of a Start-o-matic flywheel for a 6/1 ?
They look considerably thicker than a standard 6/1CS
veggiefuel
needenginerunnin
  • interested in state of the ARK technology.
Re: Start-o-matic flywheel weight
« Reply #1 on: November 15, 2010, 10:59:44 AM »
sure i read somewhere on the net, about 130kg ish each
just measured mine and if an online program is correct, then its about rite.
needenginerunnin
« Last Edit: November 15, 2010, 11:28:06 AM by needenginerunnin »
1949 6/1 electric smooth flywheels & ST 7.5, som base x3, cast indoor silencer X2.
1950's 6/1 som x2, spoked 6/1, LD1 som.
listerpetter LV2, PH1,LD1,SR1, PAZ1, AA1, LT1, AC1. 3.5hp yan clone.
politician's are like nappies, they need changing for the same reason.
take the pi$$ , full of sh#t.
bschwartz
« Reply #2 on: November 15, 2010, 02:19:06 PM »
!!!!! Is that right ?!?!?!?! :o :o :o  About 285 US Pounds ?!?!?!  :o :o
-Brett
needenginerunnin
« Reply #3 on: November 15, 2010, 03:00:50 PM »
i know it seems alot, they weigh what 400kg complete. so say 250kg for the pair, block 75kg crank 25kg, barrel 25kg and head 25kg.
cant be that far out?
anybody else know better.
needenginerunnin
« Last Edit: November 15, 2010, 03:05:44 PM by needenginerunnin »
rleonard
  • Mattoon, Illinois
« Reply #4 on: November 16, 2010, 03:20:42 AM »
I have one free that I can weigh.  I have to figure out a scale though.  250 lbs each is a good guess at the weight.
Stan
« Reply #5 on: December 24, 2010, 03:12:46 AM »
http://listerengine.com/smf/index.php?topic=2819.0
Electric flywheels which are the same as SOM flywheels (without the grooves) are 125 Kg or 275 lbs ea.
Stan
billswan
« Reply #6 on: December 24, 2010, 03:22:38 AM »
Wow stan long time since we heard from you where you been hiding?
At least I haven't noticed any posts from you lately! ;D
Billswan
Stan
« Reply #7 on: December 24, 2010, 03:29:58 AM »
Nope Bill, been real busy, building on the house the last year or so, lots of travelling, Spain Portugal last couple of months.  Finally got round to looking at Penelope again.  Got to take out the big end bearings and try and refit them, hook up the fuel system, tighten all the loose bolts etc.  Maybe first smoke when ski season ends this spring.
Things on the old forum look good!  Hi to all the old friends, Andrew, Casey, you etc. etc....
Going to try and fit in some more computer time in the future, away again back east in January though.
Stan
billswan
« Reply #8 on: December 24, 2010, 03:49:44 AM »
Stan
Working on your house well I know how that goes. I spent about 2.5 months sleeping on an air mattress this past summer when my wife insisted that part of our house needed a total rebuild. :( :(
Good luck with Penelope my 10/1 is thumping away right now but is suffering a slow death from evidently abrasive waste oil syndrome. ;D
Billswan
Stan
« Reply #9 on: December 24, 2010, 04:35:41 AM »
Ah.....they ol' waste oil vs new diesel discussion is it?  Ive got a supply of waste veggie oil waiting for me.
Stan
