Note that the thread angle of Whitworth/BSW are similar to UNC and bolts and nuts will fit, but they are not the same and should not be used/mixed randomly. Whitworth are 55 Deg and UNC are 60 Deg thread angle.
Peter
After buying my Lister VA7.5 (it's on it's way from Newfoundland) I discover there are no "ears"on the engine by which one would use a crane (which I have)to lift it easily, & have seen in this forum various suggestions to lift them the best one I found is to use 2 coupling nuts on the 2 lister head studs made longer by design to accommodate the coupling nuts to which I will screw in 2 -3/4 X10 heavy eye bolts...voila!
I have the hardware ready to go....& now I find that the studs are likely BSW....my heads starting to hurt now...
Will using the hardware I have damage the studs or ( more to the point) be unsafe?
With 600 lbs plus dangling from 2 eyebolts it would be comforting to know the threads aren't going to pull out.
I could "chase" the UNC threads with BSW tap & dies or just buy the proper fasteners from British Fasteners in New York.... but the thread types are so close!
I wish I had my dad's old tools now he was a tool & die maker a long time ago....
Edited for clarity....
