Author Topic: Update on the 8/1  (Read 16830 times)
cgwymp
Update on the 8/1
« on: October 26, 2010, 12:13:22 PM »
Got a chance to mess around with the 8/1 some this past weekend. Here's what a few hours with Mr. Needlescaler gets you. Found LOTS of sand pockets, especially around the stud bosses and in the lower sump.....
« Last Edit: October 26, 2010, 12:22:41 PM by cgwymp »
Listeroid 8/1
Re: Update on the 8/1
« Reply #1 on: October 26, 2010, 03:18:27 PM »
Amazing what they paint over aint it? Oven cleaner from the dollar store will strip the rest of that paint if you desire. If you cant find Gyptol for a decent price this is what I used. Came from WW Grainger, same stuff, different Mfg.
Used it inside and out dries hard as glass.
« Reply #2 on: October 26, 2010, 03:31:51 PM »
WHAT did you use from Grainger ?  no name / link appeared
   (nevermind - I see you linked to  i45.tinypic.com/2nvw677.jpg   which my work blocks.    I'll have to wait till I get home
« Reply #3 on: October 26, 2010, 04:47:13 PM »
Here is a link, Why are you messing around with Listers while at work???  ;D ;D
http://www.grainger.com/Grainger/SPRAYON-Insulating-Varnish-1D276
cgwymp
« Reply #4 on: October 26, 2010, 06:36:33 PM »
Thanks for the input! I've got some Glyptal lined up ready to go. I may need more though for the gen head. Do you still have to have a commercial acct to purchase from Grainger? I haven't done business with them in probably 15 years.....
To remove the rest of the paint I'm using Dawn Power Dissolver:
http://www.dawn-dish.com/en_US/powerdissolver.do
It's more expense than dollar-store oven cleaner and it's slower, but it does work (believe it or not!) and it's a lot nicer to be around.
Listeroid 8/1
« Reply #5 on: October 26, 2010, 08:46:09 PM »
I went over to Grainger looking for gray and found it also comes in clear and green but not Witte Gray so I'm back to a brush and Derusto Industrial Gray.  But green?  I wonder how close to Lister Green it is?
Casey
toydiesel01
« Reply #6 on: October 27, 2010, 03:57:28 AM »
grainger sell to everyone with no account
cgwymp
« Reply #7 on: October 27, 2010, 11:13:57 AM »
Good to know -- thanks!!!
Listeroid 8/1
« Reply #8 on: October 27, 2010, 01:55:22 PM »
I'm no account and they sell to me ;D
12 gauge
« Reply #9 on: October 28, 2010, 08:56:15 PM »
cgwymp,
After needle scaler, pressure washing is great.  After that I couldn't feel any trace of grit on the castings.
RH
cgwymp
« Reply #10 on: October 29, 2010, 12:48:14 AM »
cgwymp,
RH
Ain't it, though? My procedure was needle scaler, pressure washer, Power Dissolver, then pressure washer again. Got it clean!
Thanks!
Listeroid 8/1
Bottleveg
« Reply #11 on: October 30, 2010, 12:27:55 PM »
I’m curious about the surface texture of the casting. Is this a result of the needle cleaning, environmental exposure, or are the castings like that from new?
cgwymp
« Reply #12 on: October 30, 2010, 06:13:29 PM »
That's what was under the Indian body filler. Pretty nasty, hmm? About what I expected, though....
You should see the flywheels!
Listeroid 8/1
Bottleveg
« Reply #13 on: October 30, 2010, 07:31:01 PM »
I didn’t realise they were that bad! I’ve never actually seen a Listeroid, I’m used to handling Dursley castings. So they use filler to smooth all that over before painting?
cgwymp
« Reply #14 on: October 30, 2010, 07:47:08 PM »
Yes, thickly & sloppily. It doesn't look like typical body filler -- more like plaster of paris. They also slobber the paint on thickly & sloppily. The linkages on mine were fairly stiff before I cleaned them off.
If you'd like to see a Listeroid firsthand, I'd gladly trade you straight out for a Dursley engine....  ;-)
Listeroid 8/1
