Ah, the jewel showed up tonight. I will take a couple of pics and send them to you. For some reason the pics I was sent via cell phone will not forward into e-mail.
IT RUNS!
Bled the system, crank, ok, crank, crank, crank. .. fired up.
I need to get a tach on it to see if the rpm at wot is right.
I only ran it for a minute or two.
I see some small parts I need.... like a grease cup thing for the rocker arm lube.
There are 2 tubes near the injector. 1 is fuel in obviously. The other comes out above the fuel inlet (on the injector). It goes about 6" and terminates just to open atmosphere. What is this line for?
Thanks
Wags
Oh, can someone get me pointed in the direction of a manual/ spec book/ maintenance book??
