Hi, an 85 KVA generator I have in my shop presently, has an electronic speed governor fitted, this holds the RPM perfectly with varying loads, in fact I ran the machine with the governor detached and a fixed no load RPM set on the pump control arm (CAV DPA ) and the speed governing was hopeless at 20% load.
Now not being one to spend uneccesary cash, having a couple of generators I use for my shop power and proprietary speed governors being very expensive, I thought about the possibility of using a vehicle cruise control set up which I assume is a similar closed loop system to an electronic governor.
The problem for me, not being an electronics whizz, would be modifying the electronics of the system to suit, is there anyone who has done this or would know the mods needed ?
Thanks in anticipation,
Mark.
