Author Topic: paper gaskets  (Read 5927 times)
builder
paper gaskets
« on: July 27, 2010, 11:56:02 PM »
just finished changing all paper gaskets fittered on cooling cistem on my cs 8/1 lister, after every one leaked from new a bit of advice dont use paper gaskets at all, i have used heat risistent silicon and not a drip that also goes for the crank case inspection plate which was driping oil a bit , not now with the same silicon.
Bottleveg
Re: paper gaskets
« Reply #1 on: July 28, 2010, 12:24:28 AM »
Where did you get your paper gaskets from?
builder
Re: paper gaskets
« Reply #2 on: July 28, 2010, 05:13:02 PM »
stationary engine parts york ltd, i dont now why i just didnt us modern tecnology in the first place when this engine was built they just didnt have this stuff in a tube at a fraction of the cost was advised at s/e/p that they used paper gaskets when made,but they would because thats all they had
Bottleveg
Re: paper gaskets
« Reply #3 on: July 28, 2010, 06:41:29 PM »
Another option-
http://www.listergaskets.com/#Listerheadgasket
They have good reports on here.
I'm waiting to see if they do the complete gasket set. Although the add says 'full set' I can't see the small stuff like oil pump, fuel filter housing and the washers that go on the dipper tray, oil pipes and drain plug.
Silicon does the job but it tends to spread too much. I bet it takes half a tube to set the bump stop.  :D
builder
Re: paper gaskets
« Reply #4 on: July 28, 2010, 11:02:32 PM »
no its only the barrel water jacket inspection plates  ,the crank and breather cover plate,the flow and return cast iron threaded 1/1/4 pieces that bolts to the head,i wouldnt like to use silcone on the head, the copper one did the job, but the gasket set i did buy came with some of the pump seals ,and some i didnt even use
