Fellows, if your engine is emitting oil fumes the engine needs work! About the only exception is if the oil level is too high. Also the splasher is supposed to be hitting the oil on the narrow side, not the wide side. The oil level shouldn't touch the big end of the rod, only the splasher. If it still is emitting fumes and oil the rings are not seating well. Another thing that sometimes causes oil leakage is the reed valve on the crankcase door. Its purpose is to maintain a partial vacuum on the crankcase to eliminate oil leaks. Many engines will have paint on the reed, preventing it from sealing. Take it apart and clean it, taking care not to bend it. If you still get fumes and oil mists you might need to check the rings. I've never seen anything come out of the GM-90 PCV system, just a couple of puffs of air on startup, then nothing.
Mike
