OK, first rule of sustainable power generation: You need 2 HP for every KW/KVA(there is a difference, but I won't get into that right now) of electrical load. This rule has been proven again and again since the first electric generators were created. An 8/1 will quite easily spin a 7.5 KVA generator, but that generator set will only be able to support a maximum load of 4KVA load because the engine does not have enough HP to support any more load than that. The inertia of its spinning mass will support brief surge loads, but feed it a steady load of greater than 4KVA, and it's RPM will start to fall off/droop. For 5KVA of sustained electric load, you NEED 10 HP. The 7.5KVA head was as Compig mentioned, so that it will run a little cooler in your warm climate. The engine in a hot climate is easy, just add a biger radiator to shed more heat. You can't add a bigger radiator to the generator head, so one designed to sustain a heavier load will run cooler at a lesser load.
As for a belt drive, I am using a micro groove serpentine automotive belt. It needs no modifications to the engine flywheels to run in a constant position on the flywheel surface. The position and alignment of the generator pully in relation to the engine flywheel keeps the belt in line as it passes around the engine flywheel. The generator pully has 8 small machined grooves that the micro groove belt fits into. You can do this same thing with a standard automotive "V" belt. For 5KVA, I would use at least 2 of these. The generator would use a standard double "V" groove pulley, and the belt's inner flat faces would just ride flat side by side on the flywheel. IMO, a dual belt would have plenty of friction around better than 3/4 of a clean dry flywheel circumference to maintain 5KVA of generator electric load.
What exactly are you needing to power that requires 5KVA? The first step in any generator project should be a carefull study of need/load. I have seen a lot of people grossly overestimate the ammount of electric load they need to provide for...
