I don't have an $800 meter lol, mines a Cheap $20 Canadian tire special made in China....
Don't waste money on expensive test equipment, odds are any problems you have will be easily found with a cheap multi meter.
At work I do have expensive test equipent but thats because most of the equiment I work on is 600 v. Sometimes I need a scope to check electronics, a maudie walk to check for live circuts in high voltage switch gear or a 1000 volt meggar to check a splice but most often a wiggy or a pocket potential tester are my first choice tools.
Keep it simple, this is only 120/240 use tools accordingly.
