[quote author=Mucke
Thanks Tijean,
What happened: The brand new 12/1 blew the head gasket after 2 min. of running.
I hadnīt checked the head stud torque!
New gasket and torqued shows a 0.025 squish ! And the engine hammeres.
Than I counted the gaskets under the cylinder foot and as far as I can see there are already 5 of them.
Holy christ !
Would one really add so many more gaskets or would it be better to make a sheet metal spacer ?
Rolf
Could be too little torque or sleeve projection above the cylinder being too high, too low or uneven.
I dont know what hammering sounds like to your ears but with that small a squish, valves could be hitting pistons. Intake starts to open 15 deg. or so BTDC when valve lash is at .008 . From memory exhaust has about the same overlap. How deep the valve seats are is part of the equation. I would ease the valves down by hand in various crank positions and see how close they come to hitting piston. Remember too it is not unheard of for valve timing to be out one tooth from proper spec. If you have strange noises and leaks best not too assume that anything is correct if it could have a bearing on what you are trying to blueprint.
I prefer to use some sheet metal in place of some of the paper gaskets. They hold the torque and easier to calculate instead of guessing how much the paper ones will crush. The advantage is that you can throw a few extra paper ones in and tear out the excess without pulling the cylinder back off. You cant do that with the metal ones.
If you have to pull the cylinder, plan on replacing the O rings on bottom of sleave. You may find extra half gasket used to make the head stand true. The cylinder casting's surfaces are not always true 90 deg to the sleeve hole bore. Best to do a test fit up before putting the O rings in.
