What is that black thing in the middle of the oil fill plug, a level indicator?
Also what is the valve and hose hooked into the intake for, starting fluid?
Looks like a well made engine, is it noisy?
I need the quietest diesel I can get and so far a 6/1 Listeroid is the least noisy diesel engine I have heard so far.
Also I would be curious to know what brand and where the generator was made, and to see how it is excited and if it has brushes or not.
And you might consider just using a battery charger run off the AC if the generator turns out to be OK? Leland
Leland,
The plug is a dipstick.
The hose is connected to a small priming pump, the white knob..below it is an oil preassure indicator....you open the valve give it a few pumps to prime (still learning when and how much!) close the valve and start.
It is noisier than my 6/1 but also has twice the power. It is not bad but still makes its share of noise.
I want to go with the alternator for several reasons. I can run both the pump and charge batteries at the same time and a 100amp charger is not cheap.
Here is a picture of the label. The picture views better than my naked eye. Maybe you can see or recognize the name. I was told on the other site it was sold by Granger under the Dayton name.
Dave.....did you received my message in the other site.....
Shipo,
Yes I did or at least the most important question about what the full model number was.(the site is down now I guess) I have ordered a parts and service manual and also found the cause for the oil puking breather...to much oil! I will be on a parts mission for the seal that is on the hand crank start shaft. It appears someone tried to replace it with the wrong size…another oil leak to fix. Thanks shipo!
If that gen head doesn't work for you and you are looking for small and light, I'd look at one of the PMG heads like utterpower or georgia generators.
They are much smaller than a similar sized ST head.
bschwartz,
I have considered that option but I only have $300.00 dollars in it so far and to strap a $600.00 PMG on it makes it even more valuable. It will be going to our off grid ranch to charge batteries and pump water.....it hasn't been robbed yet but I would hate to loose it with a good head on it!
Thanks guys!
Dave
