Author Topic: lister cs diesel with pics in gallery  (Read 15570 times)
glyder61
Re: lister cs diesel
« Reply #15 on: March 07, 2010, 07:01:25 PM »
Hi gents,have carried out strip down as you advised nothing to frightening too report.Liner/sleeve seems in remarkable condition it does not even have a lip at the top in the unswept area,there are however three tiny pits one of which is just inside swept area in region of top compression ring [see photo].piston crown does have some significant pitting evident i had thoughts of using some wet or dry in conjuction with a surface plate and gently blending out.None of the rings were sticking.There is no air filter on this engine could this be a factor as to the piston crown pitts down too debris ingress.Big end,small end and main bearings no play/movement evident other than about 1.0mm endfloat on crank can be felt when you push pull on a flywheel is this servicable if not is it a matter of replacing thrust washers? Have taken some pics experiencing difficultys attaching them at the moment.Is it advisable to roughen up/hone the bore prior to fitment of new rings[chromed liner]? HOORAY have now managed to get photos on gallery
« Last Edit: March 09, 2010, 10:33:25 AM by glyder61 »
