Author Topic: Injector pump for 14/1  (Read 2600 times)
dieselman
« on: February 24, 2010, 03:41:06 PM »
I am looking for an injector pump  #9 410 032 034.
Thx, jim
aztexjiimholley@gmail.com
1995 F350 7.3L Diesel
8.3 ISC Cummins
14/1 Lovson (in progress)
Combustor
  • Combustor
Re: Injector pump for 14/1
« Reply #1 on: February 25, 2010, 01:23:17 PM »
Hello Dieselman,
                     It's most likely that the pumps are the same on most Listeroids, and only the timing and governor settings are different. so if you choose a pump for any motor of similar bore and stroke you should be OK.The Indian injection gear is normally very good and quite affordable.  Shop around your Listeroid dealers. Hope this helps,
        Regards,  Combustor.
dieselman
« Reply #2 on: February 25, 2010, 08:38:17 PM »
That is what I understand.
Ordered on from Central Maine Diesel.
Thx, Jim
8.3 ISC Cummins
