Author Topic: changing frost plug in zs1115 engine  (Read 2951 times)
purdypower
« on: January 27, 2010, 11:14:55 PM »
Changing frost plugs in changfa   ZS1115 head
The Zs 1115 has 3 frost plugs in the head two outside crank case and
1 inside
You have to remove the valve cover to find the third one, if this one pops water will enter the crankcase
This plug is a 31/32 which is not available in the US so we will use 1 inch .
But it has to be modified  to fit into the hole .  The new frost plug looks like this
If you just pound the new one in it will look like this
But if you take a file and remove the skirt down to about 1/8 of an inch or less
Then pound it in the hole
Then take your file and level up the plug and with the head as the rocker arm partly cover the plug
rain rain go away
