Author Topic: Head gasket leaking  (Read 5198 times)
somian
Head gasket leaking
« on: December 22, 2009, 10:17:48 AM »
Just reassembled 8/1 having fitted glow plug kit from Stationary Engine Parts. It certainly improves the starting. However, I am getting gas bubbles in the coolant, so clearly the new head gasket from the same source isn't sealing. I fitted it dry, with the big nuts torqued down to 100lbft, and the little ones to 65lbft.
One thing I notice is that the big hole in the centre of the new gasket is a little smaller than the old one, and is therefore right on the edge of the cylinder bore, not a little outside it.
The old gasket was a Coopers, but where I can I optain a new Coopers gasket for it. The ones from Stationary Engine Parts looks fine apart from that difference.
Any suggestions, please
Somian
quickies
Re: Head gasket leaking
« Reply #1 on: December 22, 2009, 08:08:22 PM »
Dear Somian,
I've got some copper c.h.g.'s for this engine. Have a look on my
web site at www.e-gaskets.co.uk
Kind regards,
Geoff
quickies
« Reply #2 on: December 22, 2009, 08:13:33 PM »
Dear Somian,
Forgot to add to my last posting.  The engine bore for the 8/1 should be 114mm.
The bore on the c.h.g. should be 117.5mm
Geoff
listeroil
« Reply #3 on: December 25, 2009, 09:39:43 PM »
Somian
These people are genuine lister agents and can supply genuine head gaskets for CS engines. Ask for Mike he knows all about these old engines.  http://www.sleeman-hawken.co.uk/
Mick
rleonard
  • Mattoon, Illinois
« Reply #4 on: December 30, 2009, 07:26:07 PM »
I had the same problem and documented it here.  Ended up to be a cracked head.  Not an unusual problem with a Lister.
