I am just getting my engine going so I do not have any knowledge of how it ran before this.
I was trying to see if two fuel shut off solenoids, one per cylinder, would shut the engine off in sufficient time. To do this I replaced the existing fuel line with flexible hose and used a couple of valves to simulate a fuel solenoid. When I started the engine up, I noticed only one cylinder was firing while the other was only putting out a mist out of its muffler but no heat. However when the cylinder that was working was shut off, the other started to run.
I checked the fuel lines for air and they seem to be OK. I cracked the pressure side of the injector and it had fuel coming out. The timing was adjusted by someone who knows what they are doing about a year ago and the engine has sat since then.
Is there any suggestions about the possible problem?
