Are you sure it's the compressors that are dead? Most newer fridges such as yours are run by circuit boards that handle defrost timing, temperature control, icemaker filter replacement time, etc. As are most consumer electronics, the boards are cheaply designed using the minimum quality to do the job. It doesn't take much to kill them, even though the compressor and fans are usually pretty robust as long as the condenser is kept clean. I keep a section of that fluffy blue roll filter media behind the intake grate at the bottom of our Kennmore side by side. 2/3 of the bottom is intake, the other 1/3 exhaust. I remove the grate and vacuum the filter about once a month and with two English Cocker Spaniels, it is FULL. At our previous home I wasn't smart enough to use the filter material, so I had to wheel out the fridge every 6 months and vacuum up enough fur and dust to make at least another complete dog.
Conversely, I recall the old Whirlpool top freezer model I had growing up in the 70's where my Mom would take everything out of the freezer and put in a pan of hot water to thaw the ice quickly to defrost. But, with no moving parts except the compressor, I bet that thing would still be going today, and the rear mounted condensers hardly ever required cleaning. It was QUIET, too.
Now it seems everything is Chinese. I bought a 8000 BTU A/C unit for our detached garage/shop the other weekend on sale. Whirlpool - Made In China. It's a nice unit - electronic control with remote, and the price was right $159. But like most of the reviews I read on current A/C units, it's LOUD, even on low, and it's fan noise, not compressor noise. On high it sounds like it's at takeoff power. 20 years ago I had a 6000 BTU Emerson "Quiet Kool" in my bedroom. Made in the USA, naturally, and it indeed was quiet. But I bet even back then it cost a lot more than $159 iin 1980's dollars. Maybe not as efficient as new units, but with mechanical controls (reliable - easy to fix) it would be still going today. But I digress.....
Related to this - I do notice that when I was running on generator power (Markon 2-pole 3.2kW brushless), motors such as ceiling fans hummed louder than usual, so even out of a quality generator head, the power isn't as clean as utility. But 8 hours of gen power didn't seem to hurt the fridge or freezer and that was two summers ago. Haven't needed the gen since.
Chris
