rover:
i don't know you from adam, and quite frankly its probably a good thing
you come in here with your 50 odd posts and seem to be looking for a problem.
after giving you some thought and trying to be fair, i have concluded either you are no engineer
or you are a freshly minted one trying to earn your chops by being a pain in the ass.
you make assumptions based on your limited experiences, and also assume that when i outlined a design
it was complete, both are faulty in my opinion.
the little engine we are talking about here is all of about 126lbs dripping wet, it is advertized at 13.7hp at 3600rpm, but
these engines are setup to run 2800rpm so i would expect maybe 10hp at most.
now you have an issue with tube spacers? Â when i mentioned tube i called out DOM which is a very thick wall tube
if you cut and grind the end square and then insert a bolt through into the block and torque it properly you will do well
to get any measurable deflection at the distances we are talking about,, (less than 6 inches total), you use 4 of them
and torque up and it will be dead on and rigid as hell, to say otherwise is showing your inexperience.
if you are concerned with squareing the ends of the DOM, simply take them to an automotive machine shop and have
them chucked into a sioux valve grinder, using the stem grinder they can be made equal length and perfectly square.
now once assembled, there is nothing saying you cannot insert web triangulated truss supports from the outer plate to the outer
end of the tube. a couple such webs would make it near impossible to deflect under any normal circumstances.
this system i have related is not of my own design, but rather own borrowed from industrial equipment of thousands of hp
you claim i have no way to keep things square?
i wish you lived closer, i would love to show you methods that you likely have never been taught.
think about it a bit, the plate is as precision as needed, the standoff dom can be machined to .0005" tolerance
so the outer plate can be positioned near perfectly parallel to the oem plate
and when it is all said and done the lovejoy will tolerate a couple thousands, and the flange mount brg is self centering
and can tolerate several degree's if one is sloppy.
there are hollow dowels as well, that could be used with a bit of effort to perfectly locate the assy, as well as solid dowels
and taper pins to lock down the location of the flange brgs after alignment.
i don't know where you are coming from, but attaining precision can be done without machine tools, given a good eye, and enough
time.
i build this stuff with some regularity, and i repair others products even more regularly
i can't imagine how you think this is an inferior method, perhaps you don't understand the processes involved?
again, no body is forcing you to use any particular method.
maybe you should go get a ton of concrete and have at it?
