Author Topic: Where and how to put the thermostat?  (Read 9318 times)
jedon
« on: August 23, 2009, 07:28:29 PM »
I'm trying to get my cooling system set up and the hole where people put the thermostat seems very small, I guess I grind it out?
Hmm linked picasa pics don't seem to show up, pics here:
http://picasaweb.google.com/jedon13/MetroLister61#5373223928695472386
and here
http://picasaweb.google.com/jedon13/MetroLister61#5373223968704582866
Radiator is from a 93 Mazda RX-7 ( 255HP ), I was thinking of putting a small AC box fan near it to help with cooling if needed.
I got some galvi pipe fittings, one of the adapters has outside thread that fits the radiator hoses.
Not sure if I should put the radiator outside the shed, we do get 5+ feet of snow in the winter.
Thanks!
-Jedon
« Last Edit: August 23, 2009, 07:31:57 PM by jedon »
Irish Artist
    • murphyillustrates.com
Re: Where and how to put the thermostat?
« Reply #1 on: August 23, 2009, 07:34:01 PM »
Yes, indeed, I had to do a fair amount of grinding on mine. I also ground out the housing a bit to allow the thermostat flange.
Murph'
PS 6/1 • PowerMac G5 Quad • An Electric Pencil Sharpener • 10 foot Trebuchet • Woodford Reserve & A Fine Cigar, life is good!  8)
listeroil
« Reply #2 on: August 23, 2009, 09:39:30 PM »
Jedon
Another method is to use another flange. Bore out the middle to suit your thermostat and use longer studs. It works very well.
Like this
Mick
jedon
« Reply #3 on: August 23, 2009, 10:08:03 PM »
Looks good, is that the one someone said was some kind of plumbing part? Where would I aquire such a thing?
Irish Artist
« Reply #4 on: August 23, 2009, 11:09:47 PM »
Hey Jedon,
That Thermostat seems rather big, from what I can tell by your pics. I'm using a smaller one, NAPA part # 550095.
If you do any grinding on the head pull if off the engine, I stuffed a rag in to the recess and then I blew the water jacket out once completed.
M61hops
« Reply #5 on: August 23, 2009, 11:30:16 PM »
Hi Jedon, welcome to the forum.  That thermastat you have seems much larger than you could fit into the port in the head, I'd find a smaller one to start with.  I'd also make a flange like listeroil did so you don't ruin the head by trying to grind out too much metal.  You don't want to break into the head stud cavity  :( !  Also if you make a flange you could set up a bybass loop to heat veggie oil or at least even out the temp rise on the cylinder and head during warm up.          Leland
NoSpark
« Reply #6 on: August 24, 2009, 05:54:30 AM »
The double flange kit is sold by some oid dealers and came standard on some engine brands.
Anand Powerline 6/1 ST5
jedon
« Reply #7 on: August 28, 2009, 03:50:47 PM »
Looks like George at Utterpower has them for $30.
12 gauge
« Reply #8 on: August 28, 2009, 11:51:08 PM »
jedon,
You may find a common flange used on heating system boilers that would work.  I used the rubber gasgets made for the same, and found them very good.
RH
jedon
« Reply #9 on: August 29, 2009, 04:20:30 PM »
12gauge, what kind of store would have that? Plumbing supply? Home Depot? HVAC?
Thanks!
Stan
« Reply #10 on: September 28, 2009, 03:19:43 AM »
Just don't try and use extra gaskets on a cast iron fitting that is cinched extra tight.  You'll hear a "clink" sound while tightening and by then its too late.  Ask me how I know.  :-[
Stan
