Is your setup using just the pressure switch to operate the pump?
Yep, just a Square-D pressure switch. That's why they install 2-wire pumps - they are cheaper and do not require any sort of control box like a 3-wire pump. Franklin also uses a BIAC rather than a mechanical switch to disconnect the split-phase start winding, so it is a pretty robust setup. Since we have 200A 240V service, nobody cares about starting current demands. Just bore the hole and drop in whatever is cheapest.
On a side note - hopefully our water table will hang in there because there are a LOT of people on wells around here and we are in a pretty upscale area so there are quite a few homes with underground sprinkler systems keeping an acre or more watered. I do like green grass, but I am not going to waste water or electricity to have it. And of course, it will be MY well that goes dry due to my neighbor watering his yard in the middle of a 90F day with 20mph winds blowing......
