Could you explain how you plan to use the temp switch to activate the decompresion?
AND
Have you looked at Datakom controllers? They are quite cheap and can be monitored from online Look at DKG-317. One glitch: the starter is programed to disconnect at 15 herts and this is not changeable.
Hi jsw123, sorry, but I think u misunderstood me, I meant that the temp switch is wired to the high temp input for monitoring and shutdown, the controller monitor the temp input and switch the engine off with the solenoid. this is if your controller does have that facility obviously, but I think most do as that is the most common thing to do. You can also get the temp switch to switch a relay to disconnect the solenoid when the over temp is reached.
I'm not sure of your knowledge of electrical systems, but this is quite straight forward and I can happily draw you a cct diagram if you wish. (Actually I think I saw one somewhere on this forum, but it could be on another)
About Datakom's products, I'll try and see if they are available here in ZA. That "glitch" is quit severe! By the time it reaches 15Hz, some electronic ccts, like TV's and my beloved PC, definitely wont like that and will probably fail if its a slow decrease of frequency, but that's debatable and a whole other subject.
One can buy a over/under frequency monitor and use that to switch the engine off, but that's defeating the object if you buy a new controller that cannot monitor properly!
I would like my controller to monitor water temp and frequency between say 47&53Hz. If these are out of bounds, it should switch off the engine via the solinoid.
An aux input to monitor fuel level would also be nice, I hate "bleeding" the CS fuel system ;-)
It should also have Auto Start, not just a momentary switch like starting a car and I decide when the engine is running. (I would like to remote start it, say from the house)
Let me know if I can be of any further assistance,
dubbleUJay
