Steve that looks pretty good
. I'm not concerned about the minor DC pulses to the field/slip rings
Tis the nature of the beast with a single phase input to the AVR with two zero voltage evens per cycle/120 per second. And normal for a "switching" power supply that doesn't use a transformer to achieve the desired voltage.
The noise/spike/pulse on the excitation and it's refection on the AC output wave. Should be rendered from being a very minor concern to no concern with the addition of a beefy DC filter cap across the leads supplying the brushes.
Almost every machine shows noise and spikes at no idle and they smooth out when loaded.
Of course I've made the 2-1/2 hr trip to London about 6 times in the past year not knowing
about your AVR's being located there.
