two of the most fascinating alternator designs of all time in my books
are the electodyne and the delco 30dn
the electrodyne for its brushless, built to take a nuclear hit, work forever construction
and its rather unusual colapsing field induction method sets this bad boy ahead of all the rest in my opinion,but
relatively rare around here and bloody expensive.
the delco 30dn, is for all purposes the 3 phase rectified equivalent of the st head
except it is superior to an st in almost everyway as far as constuction goes, but lacking size sufficient
to be of any real use today, i did rewind one for 120vac 60hz which the 30 dn can do at 1800 because of its
4 lobe rotor and nice clean sine wave due to its skewed stator, they were nice units about 40 plus years ago.
lb for lb, amp for amp, dollar for dollar the 555 is hard to beat in my books, i got my hands on one of the old motorola's
back in the late 70's, but could not keep it because of its heavy core charge at that time,, but the design damn sure got my
attention and when leece neville ended up with the rights to it and then prestolite, i was very excited about the rerelease as the load handler.
before that thing came out i was a die hard delco fanatic, pffft, you couldn't give me a delco today
save for maybe another 30 dn or certainly an aircooled belt driven 50dn (always wanted one of those)
i remember 25 years ago an 80amp delco 1100080 alternator went for 275 dollars rebuilt and you better have a core to
turn in, the core was about another 250bucks iirc, and to buy a new one?? ya right they were so bloody proud of those things
that i don't remember every installing a new delco 80 amp alternator, they must have been over 5-600bucks way back then.
so yes, when the 555 alterator first came out, i was all over those puppies and have installed them exclusively in every appication
where i can make them fit, ditching the delco's, leece neville jb series, ford blue backs, bosch or any other creature that takes
a j180 mount.
the thing that really surprises me is why more folks haven't discovered these units and still scour the junk yards looking for old
ford, gm or dodge alternators, that couldn't keep up with a 555 if you cooled them in liquid nitrogen.
anyway, back to the topic at hand
compig:
your comment about this being a religion?
well not quite, certainly a lot of other things a guy could do that would be less productive with his spare change and time.
for me it is based on a lifetime of working on this stuff and never being in a position to test and question
much less get good answers to my questions. a good friend of mine whom will remain annonomous (man my spelling is crap)
told me not long ago
"bob, for god sakes quit researching and theorizing and get out in the shop and built it" "then do your testing and see what you come up
with"
well i did
an i found that for every question i got an answer for 10 more questions popped up, and the race was on!
along the way one learns a lot about stuff he never thought much about before, such as microcontrollers.
and sometimes when you set out to really do serious research into an area where most folks fear to tread, you
get lucky and your theories work out to be reality, and sometimes you get really lucky and stumble into some
really useful stuff.
my only wish is that there were more folks out there really getting serious about how far they can push the envelope
beit in max power, alternate fuels, efficiencies, and most of all retesting long held beliefs to see if they still hold water
using the stuff we have today to work with.
case in point, "bob you don't wanna work with automotive alternator's, they are only about 50% efficient"
well maybe that was the case in 1965 or 75 or even 85, 95 or now, but
how do we know if we don't run the tests ourselves, and do our own alterations, modifications and see if maybe
alternators have changed a bit since the came out in widespread use in the early 60's? perhaps it is the methods that
were used to alter or modify that were the problem? who knows without revisiting the issue.
so yes call me crazy, i could care the less, but
i have found 25 percentage points in gained efficiency, have also found 50 to 100 percent gain in output power as well
and to be honest most of it was there all along, just not many folks were looking and the oem's until the last 10 years
have had no motivation to go looking either,,, you bet they have been though as we move to the new 42 volt standard.
i would just like to see more serious testing, more interest in doing more than buying an engine coming here and asking the same
old questions about sand, non rotating lifters, leaking fuel lines complete with another fifty 640x480 32bit glossy pictures of the listeroids
bowels... it gets a bit boreing at least for me.
but i am not bitching about that, fine with me, keep bringing the pictures of indian real estate, maybe one day someone will
find a 2 carat diamond running around in the basement
i can be tolerant, all i ask in return
is a little tolerance for those of us that want to stretch the boundaries a bit, and maybe more tolerance for those that seem to be
stretching the boundaries all over the place. if we build it we oughta be able to discuss it here? right?
anyways i am ready to read more about those that are either thinking of, or are building co or trigenerators, control systems and other
stuff.
