here is an interesting alternative
take your perkins/cat/shibura engine
set it up and run it at progressively slower speeds in an effort to find the lowest speed that it will run
and still do so relatively smoothly, lets say that speed is 1500rpm.
call this speed idle, and set your plc code to match this parameter
drive a pair of hd large frame alternators, such as the 110-555jho for ease use the 24 volt versions
connect the outputs of both altenators in series for 48 volt operation and both fields in parallel so that
a single 24 volt balmar or xantrex controller can regulate and take control of three step charging.
charge a set of golf cart deep cycle batteries 48 volts at about 225amp/hr is sufficient
use an inverter of 5-6 kwatts for perfect sinewave, rock solid 60hz power
now go back to the engine, and particularly the fuel rack
control the rack with a current solenoid with a shunt, using a bias spring
by tailoring this spring and useing the current flowing from the alternator to the batteries
you can alter the position or pull of the solenoid on the fuel rack
low load will pull the fuel rack up off of idle, medium load will pull to approx 1/2 throttle
and full load will pull the rack full open.
it does not need to be highly accurate, because we don't need tight freq control off the alternators
the inverter does that all by itself.
the plc/controller can initiate a startup, run at idle for a predetermined length of time, then close the relay to
trip on the balmar/xantrex which in turn will turn on the field of the alternators, after which time the dc amps delivered by
the alternators to the batteries via the current solenoid which controls engine rpm
now you have an engine that can idle and sip fuel quietly as possible, until there is a load, then it can throttle up
as much as is needed to suit that load, and you have batteries to buffer with and provide power in a black out long enough
to get dressed and go fuel up and do a startup of the genset if need be... or
the plc can be used to automate this process, and not do a startup if the blackout is of a short predetermined length of time
and do a startup if it is longer period of black out.
properly done, finely tuned a system such as i described will compete favorably with a fixed speed listeroid/st genset
in fuel consumption, leaving the question of longevity as the only thing left unanswered.
