you find a good, definitive, and correct answer to that last one (power factor with the use of rectifier loads)
and i will pay you 10 bucks!
seems there are lots of folks that understand powerfactor to various degree's, even electrical engineers argue
about power factor in its most common appications, but
try to find two electrical engineers that agree on the merits of power factor with the use of a rectifier...
good luck, i ain't found it yet,, and i have been looking high and low.
seems i will be forced to get it illustrated on a scope, and then work with various methods to alter the powerfactor
from what i think i understand it is a very difficult beast to get a grasp on and make any meaningful correction.
even after all that is done, the gains in efficiency are very low, you basically are increasing output only by the amount
of heat reduction in the stator,,, that likely is very little (maybe a percent or two at full capacity)
good question
