MK:
i like the way you think!
from my perspective and knowing human nature of the typical DIY'er
usually we diy'ers cut corners whereever we can to save a buck, in materials and proper tools and anywhere else we can
the result "could" be a system made up of copper tubing flaired with a cheap or improper flaring tool, assembled with the cheap
non shouldered flare nut fittings, not enough of worse no support from vibration, and a crack will develop in the flare sooner than later.
now in the summer we keep things closes up tight, don't want to lose that cold air
if we have a small leak develop with propane, we should smell it right?
not necessarily, the human nose dulls out fairly quickly to a ambient smells, so if it comes on slowly we might not detect it at all.
but there is so little propane in the system? oh really! what 2-4 lbs or more?
maybe we can lose a lb and not have enough loss of cooling capacity to know there is a leak.
1 lb mixed into the air in a tightly enclosed space??? i wonder what the percentage has to be in the air before you have
an explosive mixture? if you have batteries in an enclosed space it don't take much hydrogen gas to lift the roof, blow out the walls
and otherwise make for a really bad day.
certainly there is nowhere near a lb of hydrogen comeing off the batteries in any single charge/discharge cycle?
one thing to use it in a combine cab, or tractor cab, or even a meat locker out behind the shop, or ice house
but maybe quite another if it is used in a house where humans habitate?
most especially if you are not very good with refrigeration, its practices, tooling and proper fittings, tubeing etc
most of which is not cheap and commonly available at homedepot or ace hdwe.
i think it would be interesting to use propane, but i don't wanna hear about a forum member who blew up his house, or killed himself
or his kids using it.
thats all it would take for the government to outlaw its use to the point of making it a felony for anyone caught using it if even for an icehouse out back where no one can get hurt.
jsut a thought
