So, here goes:
First, here's a bunch of pictures of the linkage, assembled & disassembled:
And then, the drawings of each bit + dimensions:
Now somehow - don't ask me how, I managed to fail technical drawing, back when I was at school.... I've no idea why
The bits I missed off the drawings....
The thickness of the slide bar is approx 1/8"; and the bottom adjuster is formed from a 1/2" square bar, with the corners filed off (presumably to make it look a bit tidier & to prevent finger cuttage.
The pins are roughly 1/8" diameter, but I don't suppose that's particularly critical. The spring has a couple of washers around it's (captive) pin, I guess to make sure it doesn't bind on the slide post.
The 1/4" hole in the "foot" of the slider bar is large enough that the adjuster passes cleanly through, and is not threaded.
Interesting that there's subtle differences between the spring & bottom adjuster between the photos I took this morning (showing the running engine), and of the disassembled pieces (from the non-running engine)... e.g. the lock nut is at the bottom of the adjuster on the running motor, and the spring doesn't have a "captive" pin.
Right, that's your lot for tonight
I'll be back there tomorrow afternoon, after the British GP if you want more (so about 3pm... GMT+1)
