not necessarily true
there certainly are real diesels that run at 11.6:1 (ntc400 cummins albeit turbo)
the changfa s195 idi is 20:1, but
the varient di engine is 15.5:1 and uses less fuel per hp or kwatt
efficiency in theory goes up with comp ratio, along with other things like friction
so you get to a point of diminished returns
generally good design dictates using no higher compression ratio than that needed to provide
for ease of starting, in the climate the engine is targeted for, burning the fuels that are commonly available.
there is a lot more to efficiency than compression ratio, so raising it chasing the last bit of efficiency
is likely the last path i would take.
millions of real diesels have been built that run in the 15:1 ratio range, with as many below as there is above
i would expect.
