Author Topic: Model Designations??  (Read 7798 times)
Piston Bob
« on: March 17, 2009, 07:10:59 PM »
I have a question.
Is there a place with the model numbers (CD, JP, CS ect) with a description of the design and operation? ???
I am thinking of getting a Lister or an Indian copy, but I am confused about which model I would be satisfied with. I think the CS is the only copy that the Indians make. :-\
The CS is the only one I somewhat understand. I have found a couple of sites that list the different engines, but there are no pictures or descriptions.
This fourm is a great wealth of information. I look foreward to reading it every day, even if I do not understand all of what is said.
Thanks!!
compig
Re: Model Designations??
« Reply #1 on: March 17, 2009, 07:18:12 PM »
There are sites with some info but the best source for the full story is a book called The Lister CS Story by David Edgington , available off ebay and David's own site.
Lister A
Onan W3S Genny
Petter A1
Villiers C45 industrial
Oilengines
« Reply #2 on: March 17, 2009, 08:21:01 PM »
If you are talking about Lister engines, then it isn't too complex:
First diesel - 9/1 which is also known as the JP or Joint Product engine (after a deal that Lister did with Ruston & Hornsby) Made in 1 to 6 cylinders, went on to the JK and JM versions, most famously known for the searchlight generators in WWII. Block and crankcase in one piece, separate heads.
Second diesel - 5/1 which became known as the 'CS' to many. Produced as the 3/1, 5-1, 6/1, 8/1, 10/2, 12/2, 16/2. There was also a 3-1/2 /1, neither of the smallest HP versions were made into twins, all of the twins were developed from and used the cylinders and heads from the singles.
5/1 and 6/1 are the same engine, 5/1 is 600rpm, 6/1 is 650rpm. 8/1 and 16/2 are much modified versions with no compression change-over, higher speed and ali piston. Block separate from crankcase, exposed pushrods. 3-1 and 3-1/2/1 have unique block, head and piston.
Third diesel - CD and CE, much more modern than the 5/1 but didn't last beyond the late 1940's. 8hp and 16hp at 1000 rpm. Block and cylinder combined, separate head. All enclosed. Gear pump lubrication, double main bearings each side.
Fourth Diesel - FR series, 1 to 6 cylinders, all enclosed, single flywheel, very complex. Block and crankcase combined, totally enclosed. 1200rpm.
Fifth diesel - VA - developed from the 8/1, basically an air-cooled vserion. Same as 5/1 etc., block, head and parts are unique to this engine.
The 8/1, 16/2 and VA do not have the compression change-over valve which all the others have.
All are water-cooled except the VA.
All are plain bearings on the crankshafts with various types of lubrication systems.
The CS and variants have many different flywheel types, from spoked to solid with cut-out, to the Start-O-Matic types. Only the CD and CE have as many variants but they are all solid with cut-outs. The VA has plain or belt grooved flywheels, both types are solid with cut-outs.
Injection equipment is generally CAV, injector nozzles and pumps can be interchanged to a degree on the CS singles and twins, but from the 8/1, 16/2 and the VA have different injectors altogether, but the pump is virtually the same.
That's most of the relevant points.
Pare
« Last Edit: March 17, 2009, 08:27:22 PM by Oilengines »
AdeV73
« Reply #3 on: March 17, 2009, 10:50:49 PM »
Pare,
Good summary, but there's a few missing isn't there? e.g. HR, LR, ST, TS, TR, SL....? I think they're all diesels, some of them air-cooled...
Oilengines
« Reply #4 on: March 18, 2009, 06:49:28 AM »
There's a huge amount missing, but the later air-cooled engines aren't really what people are looking at on here, it's the eariler water-cooled engines which is what I listed.
Pare
AdeV73
« Reply #5 on: March 18, 2009, 09:35:31 AM »
Fair comment - it wasn't meant as a dig...
Piston Bob
« Reply #6 on: March 18, 2009, 01:24:14 PM »
Thanks for the replies!!
I guess I know even less than I thought.
Yes, I am more interested in the liquid cooled, but knowing which ones are air cooled is good information to have.
Is the book on ebay.uk or the US version? I am located in the US.
Thanks again.
compig
« Reply #7 on: March 18, 2009, 02:02:26 PM »
just for you , http://www.stationaryenginebooks.co.uk/listercs.htm
You can order direct from David on the site.
Lister A
Onan W3S Genny
Petter A1
Oilengines
« Reply #8 on: March 18, 2009, 07:17:21 PM »
I didn't think it was, I understood what you meant  ;)
Pare
Piston Bob
« Reply #9 on: March 19, 2009, 01:07:08 PM »
compig, thanks for the link.
I was all over George’s site when I stumbled on to the link you steered me about the CS.
Now to get the book, read more and then find an engine.
