Hello everyone
Here is a pix of one messed up heat exchanger!
The tube sheet comes out pretty easy so I pulled it out, the tube inside diameter is .205 inch smaller than I thought!
Geno's advise to use a pressure washer cleaned it up good as new.
First I took the filthy thing to my old shop and ran an 1/8 inch brazing rod down down a few of the tubes, it went through easy even though it looks hopelessly plugged. The gunk was not dry it was wet and greasy, so the pressure washer with soap blew it right away.
Jens your tubes are much larger,yours is what I was looking for but this is what I ended up with. One good thing mine is low grade stainless so if I ever conceive of a way to keep it clean it won't corrode away. I need a carbon trap.
There are a couple more pix over at the gallery for those following the saga.
Mobil bob , gee build a heat ex. for 75$ in an hour that would be great. Yes give us some more clues how it self cleans, Please!!!!
billswan
