Bob B:
in many ways this discussion in as much as i am taking part is in reality apples to oranges in many ways
my experience with resilient mounting of these engine's centers on the changfa 195 series, and the vast
majority of others are using 6/1 listeroids and a handful of listeroid twins.
out of curiosity, and wanting to learn from where i can (so you are the professor like it or not)
i have a few questions if i may
1. you mention your wineglass test, so out of curiosity i did the same with the cradle mounted changfa
to see what the outcome might be, i have no ripples and no distortion in the light reflected off the surface of the
water in my glass,, (sorry i don't drink wine, and all i had was an unopened bottle of white wine, and figured it is near clear
like water), so i think i am on par with your experience with your listeroid, but
my hat is off to you being able to tame a listeroid which is running at one third the speed, is likely far less refined and has
no counterbalance shafts like the changfa.
because of my cradle design the engine is able to flutter a bit at the air cleaner and the starter (opposing ends of the engine)
and i can locate the center of this movement on the timeing cover with a pencil, a place where there is very little almost inperceptable
movement up/down, side to side or precession (if there is any it is very difficult for me to determine or witness, much less measure it)
this centerpoint corresponds with the crankshaft centerline, so my crankshaft is not moving anywhere out of plane, although it is free to
do so on startup and spooling down when it passes through its critical speed. (i have lost my hand tach, so i can't tell you what that speed
is with any certainty, but would expect it to be somewhere around 500rpm)
so my questions
1. is there any harm in allowing the engine to run in this manner? if so why?
2. what possible unintended stresses might there be to the crankshaft?
3. from what i remember of your setup you have the resilient mounts under the subframe of your genset,
what if any movement does your crankshaft do when running at no load, partial load and full load?
4. have you witnessed any up/down, side to side or precession at the end of the crankshaft?
5. if you have movement does it seem excessive to you?
6. can you determine if there is any precession taking place?
i ask these questions because it is not everyday i have someone that is not only an engineer, but also someone that
has a resiliently mounted 6/1 listeroid.
i hope these questions are not trying your patience, i for one like to learn all i can, where i can, especially from someone
in the know such as you.
respectfully
