Sorry sailawayrb - I wasnt clear.
Lets say the wheel turns at 6 rpm
The big sprocket (60") drives a small sprocket (7") on a 2.5 inch shaft. So we have about 10:1 - so the 2.5 shaft turns at 50 rpm. I have a tachometer and have checked this.
The 800 pulley turns @ 25rpm as its on the same shaft. This turns a 132mm pulley currently - which in this case would be turning at 300rpm.
The wheel is turning far far too fast - about double - so not only do I need to spin the end result up by double - I also need to slow the wheel down by half - so I need a 1:4 ish gearbox.
edit - theres some pics on here http://www.navitron.org.uk/forum/index.php/topic,3113.0.html if you want to see it.
Guy
No worries, I'll work the numbers again…this is an interesting project. The pictures help and look great.
The wheel (60 inch sprocket) to 7 inch sprocket ratio is 8.6 (i.e., the 7 inch sprocket rotates 8.6 times as fast as wheel). The 7 inch sprocket is on a 2.5 inch shaft. You have measured the 7 inch sprocket (and hence the 2.5 inch shaft) to be rotating at 50 RPM. This would imply that the wheel is rotating at 5.8 RPM. This is consistent with your 6 RPM estimate for the wheel.
There is also a 800mm (31.5 inch) pulley on the 2.5 inch shaft. The 800mm pulley is therefore rotating the same speed as the 2.5 inch shaft, 50 RPM. The ratio between the 7 inch sprocket and 800mm pulley is therefore 1.0 as previously stated. Is the 25 RPM you stated a typo or am I missing something?
The existing 800mm pulley to existing 132mm pulley ratio is 6.06 as previously stated. This would imply the 132mm pulley is currently rotating 6.06 times as fast as the 800mm pulley or 303 RPM. This is consistent with your 300 RPM estimate.
So you have several options. You could continue to use pulleys, but replace them with a new set of pullies that provides your required ratio. To go from 300 RPM to 500 RPM at generator shaft, seems to me you still need to increase the existing 800mm/132mm pulley ratio from 6.06 to 500/300 x 6.06 or to 10.1 as previously stated. Please see my previous recommendations for doing this. You could also scrap the pulleys completely (i.e., the 800 and 132mm pullies) and replace them with a gear box that is connected directly to the 2.5 inch shaft which you appear to prefer. However, this gear box will still need to provide this 10.1 ratio, right? You are still trying to transform your 2.5 inch shaft 50 RPM (i.e., input to gear box) to 500 RPM at generator (i.e. out put of gear box), right? Is the 4.0 ratio (i.e., "1:4 ish gearbox") you stated a typo or am I missing something?
Maybe the "something" I am missing is your desire to slow the wheel from 6 RPM to 3 RPM? I assume you will accomplish that by controlling the flowrate of water into the wheel. If the wheel will be rotating at 3 RPM (i.e., half of 6 RPM) and you want the generator rotating at 500 RPM, seems to me you would need to essentially double the previous 800mm/132mm pulley or gear box ratio calculation from 10.1 to 19.4 (i.e., 3 RPM at wheel x 8.6 x 1 x 19.4 = 500 RPM at generator). So I am thinking you need a 1:20 gear box?
