what a lot of shit, I asked a reasenable question and what do answers do I get MOSTLY CRAP.
what a waste of time!!!!!!!!!!!!!!!!!!!!!!!!!
Well Tigger, that's the way it goes sometimes.
A large percentage of the time that Fawkes puts his $.02 in, things go quickly down the toilet.
Do a long search for past threads that Guy has spouted his wisdom into, and you'll understand...
I can't pretend to approve of converting a *genuine* Lister from plain bearing to TRB, BUT, if you have to do it (for whatever personal or technical reason) and you're SURE that the bearings are fully seated and that there were no burrs anywhere holding things apart and that you REALLY need to take up 4mm of "slack" to make it work, I don't think it's the end of the world and your kids probably aren't going to die in a horrible accident because of it....
Keep in mind that you need to keep the crank correctly centered in the case so it doesn't "interact badly" with other parts. If it's offset to far to one side it can hit the cam, etc. You may need equal thickness shims on both sides, or you may need to offset the crank in one direction or other to get it centered correctly. That's YOUR call.
If you *need* to make up a couple of steel shims to take up the extra space, then you can either make them yourself if you have the tools and patience, or have a shop with a plasma or laser cutter burn them out for you.
I don't know if a genuine Dursley 5/1 and an Indian 6/1 share the same bearing housing gasket pattern, but if they do, then here's a DXF file of that may be helpful to you...
http://www.weirdstuffwemake.com/sweetwatergems/geek/misc/lister_main_bearing_gasket.dxfI drew it for a 6/1 'roid. You can print it out on paper and cut it out to make gaskets for your beast, or if you need to have steel shims cut out, any good metal shop that has a plasma or laser cutter should be able to use the DXF file to cut what you need. If you use it to make steel shims, print it on paper first and make SURE it fits your hardware correctly.
Good luck. Don't let Guy scare you off. He means well, but he kind of goes over the top sometimes...
