Aaaahhhhh Yes.
That's what I'm talk'n 'bout Â
Thanks Tom and Stan they are great pics!!!
I see the bit I needed to see...where you have bolts mounted horizontally to stop the "lift off".
This kind of detail is rare and I thank you both for the effort of uploading and posting.Â
Stan, I am about to embark on a timber frame exactly as you have made - I even already planned to cut in the cross beam joints as you have done.
Have you had any problemss with mounting the Lister directly to the beam without a piece of iron plate in between?
I was thinking of the pros and cons of this method because of concerns about the effects of the constant pounding of the engine on the timber, and that it may compress the wood at the mounting point and therefore loosen the engine mount. Also, the possibility of the timber becoming oil soaked from leaks etc, makes me worry about the long term effects on the reliability of the mounting points of the engine.
How's it hold'n up nowadays?
Did you use a hard or softwood?
Hopefully I too will secure the engine directly on the wood beam. Nice and easy.
regards,
Matt
