Author Topic: valve clearance on chinese diesel  (Read 6673 times)
KellyR
« on: December 08, 2008, 03:10:36 AM »
I've got a JD R180A with a manual in Chinese.  I haven't been able to find a translation anyplace and can't figure out what the valve clearance is supposed to be.  After sitting on this for a year, I want to get this back up and running.  Thanks for any info.
Kelly
Petersbpus
Re: valve clearance on chinese diesel
« Reply #1 on: December 11, 2008, 06:58:47 PM »
Kelly,
I also have a R180 project on hold while others have taken priority,
I went and dug out my manual, OH OH all in Chineese :o
I could check the current clearances, It has been well broken in but never touched the valve adjustments.
my 1115 is Intake .035 exhaust .045.  I would venture a guess  on the 180,,,.
any difference would be a factor of the total length of the push rods and valve stems :-\
so maybe .025 and .035 ? just be sure at full temp there is still clearance.
Bob P
Listeroid 6/1 in progress
Alllis Chalmers 60KW 3 ph
Changfaoid 12KW w/  auto shutdowns, modern AVR and panel
2nd Changfaoid 12KW Marine conversion w/ full auto shutdown and remote panel
Changfaoid 7.7 hp driving 5kw alternater /inverter,
other diesel gensets bought fixed and sold
KellyR
« Reply #2 on: December 12, 2008, 05:38:24 PM »
Thanks Bob.  I'll try those clearances and see how it works.   I've still got a fair bit to do until I can try running it.  There's a new stand on the way (painted bright red) and I need to figure out the cooling situation.  I've got a 30 gallon water heater that I need to strip to the bare tank and ad hoses to, not to mention decide how best to keep it upright.  We'll see!
Kelly
« Reply #3 on: December 12, 2008, 06:16:48 PM »
the changfa s195 has the following specs
.016" inlet
.019"exhaust
i would expect the 180 series to be a bit less
maybe
.014" intake
.016" exhaust
is probably very close to spec, certainly close enough for the girls i run with :)
