Author Topic: Got it!!!!!!  (Read 56432 times)
Wizard
Re: Got it!!!!!!
« Reply #120 on: March 19, 2009, 01:01:06 PM »
Few engines on the youtube I noticed some of them had repair patches over the cracked block especially if the break is just a hole.
That one I saw on your CD engine shouldn't be that bad as it's only on relatively flat surface where thick plate and screws/screws/even rivets can do that.
Cheers, Wizard
Ironworks
Re: Got it!!!!!!
« Reply #121 on: March 19, 2009, 06:23:30 PM »
If it's a water jacket crack you can repair it with JB Weld.  Make a small groove following  the crack with a grinder, fill will JB Weld or suitable epoxy, let cure, sand , and paint.  I've had good luck with this method.  You can also weld them up with wire feed welder set on low, I've had good luck with that as well.
Re: Got it!!!!!!
« Reply #122 on: March 19, 2009, 09:55:30 PM »
I agree with Ironworks.  JB Weld may not be rocket surgery or brain science but it often works in the most surprising challenges.  And veteran welders have been doing cast iron almost since electricity was discovered as well.  And that's the sequence I'd try.  $7.00 of JB Weld and then if that fails you fall back to either the master of wire feed or a really old master of the stick welder.  My limited experience with JB is that it doesn't have great strength in its self so if this crack is where it has to do some work then a bridge of similar metal between the two sides would be most advantageous ::).  I don't know if the instructions include washing liberally with brake cleaner but it can’t hurt.
Sometimes you’re lucky and sometimes you’ve got a great set of parts that will be really handy when the right block comes along.  I think we are now looking into the throat of the glaring problem of the CD.  They ain’t many.
Casey
Oiler
Re: Got it!!!!!!
« Reply #123 on: March 20, 2009, 08:43:15 AM »
The fact that threre are't many CD's made, is the main reason why i might try to repair.
It is just that the hole is located in the inside botton of the block.
In fact, there is missing a triangle between one corner and the sleeve :-(
1962 CS 6/1 for cutting firewood.
Armstrong Siddley AS1 for sale.
1937 Lister D
1918 Lister L
apogee_man
Re: Got it!!!!!!
« Reply #124 on: March 22, 2009, 07:20:29 PM »
Torsten,
Would it be possible to take a picture of the area and post it on this site?
It would be very interesting to see what you're dealing with.
Also will give other potential CD purchasers knowledge of where to look for possible damage.
Keep going at it!
Steve
« Last Edit: March 22, 2009, 07:33:47 PM by apogee_man »
Oiler
Re: Got it!!!!!!
« Reply #125 on: March 24, 2009, 08:17:12 AM »
Lucky me. A guy rang me last Friday, he wanted to heve a look at the CD. He arrived an hour later bringing his trailer!!
30 minutes later the engine was loaded and payed for. Hurrahh
Even thoug i told him all about the frostdamage, he gave me the eq. of 950£ for it.
1937 Lister D
1918 Lister L
lowspeedlife
  • old iron for a new age
  • no i'm not no cowboy
Re: Got it!!!!!!
« Reply #126 on: March 24, 2009, 09:08:57 AM »
Exellent! i like it when every body goes home happy! are you going to start looking for another?
             Scott R.
« Last Edit: March 25, 2009, 01:01:09 AM by lowspeedlife »
Scott R.
omega 20/2 listeroid
Oiler
Re: Got it!!!!!!
« Reply #127 on: March 24, 2009, 11:23:43 AM »
No. I want my 'oid 6/1 chp project up and running first.
Well, dont tell my wife, but i,ve bought a D off eBay just to play with :-)
1937 Lister D
1918 Lister L
compig
Re: Got it!!!!!!
« Reply #128 on: March 24, 2009, 08:06:11 PM »
Good to hear that Torsten , you deserve some luck !!
Lister A
Onan W3S Genny
Petter A1
Villiers C45 industrial
Oiler
Re: Got it!!!!!!
« Reply #129 on: March 27, 2009, 11:07:09 AM »
Thanks
1937 Lister D
1918 Lister L
