One should easily be able to stay within a tiny frequency range - maybe 1/4 hz plus or minus. Of course this figure is grabbed totally out of the air but I don't see any reason why this wold not be achievable.
Jens
Apart from basic physics maybe.
That's the trouble with these places, those who do know eventually get bored of repeating the same lessons and go away, and all of a sudden the only voices left are the blind leading the blind.
So some VERY basic physics.
1500 RPM / 60 = 25 revs per second.
If you want 50 Hz (UK) out of a 1500 RPM gen head it *has* to be 4 pole, if it is a 2 pole you have to spin it at 3000 RPM
Listeroid at 650 RPM, 2 pole head at 3000 RPM = a 4.62:1 ratio.
4 stroke combustion cycle is 720 crankshaft degrees, 2 turns, or 9.24 head turns.
Actual power stroke is about 100 degrees of crank rotation, or 100 * 4.62 = 462 head degrees, or 1.28 revolutions.
1.28 revolutions, for a 2 pole head is 1.28 AC cycles, during which the RPM is increasing under the power stroke, the remaining (9.24 - 1.28) 7.96 cycles the RPM is decreasing under the exhaust, induction and compression strokes.
So we're talking 13% of the time accelerating, and 87% of the time decellerating.
AC electrical loads also decellerate.
Opening the rack during our 13% can ONLY counter this by INCREASING acceleration.
In physics, there are only three ways to even this out.
1/ throw away the one lung 4 stroke, say a straight six with 120 degree crank.
2/ use a 4 pole head at 1500 RPM in preference to a 2 pole head at 3000
3/ add inertia, massive flywheels.
My start-o-matic, 600+ lbs of motor flywheel mass, concentrated at the rim, nearly 75 lbs extra head flywheel mass, concentrated at the rim, 4 pole head for 2.30:1 ratio (ratios get a lot worse as soon as you go from 50 hz to 60 hz)
Holding listeroid w spoke flywheels + chinese 2 pole head to plus or minus 0.25 Hz, not a snowballs chance in hell, not with an AC load bigger than a clock radio plugged in.
