Tom
About 3 minutes into the video when he is going over the temps and flows, on that meter assembly on the ex heatex, he says that the flow is combined with the engine cooling system, and that 8KW is the sum of both systems. With 4KW of output/load, 8KW out of cooling and exhaust sounds about right to me... But if I am reading and converting his numbers correctly in the video, 240V@18A is 4320W. 4.93 Liters Per Minute is 1.3GPM or 10.4 Pounds per minute. His temps convert to 175F and 134F respectively, so he is dropping 10.4 pounds of water 41F each minute. That is 426.4 BTU/Min or 25,584 BTU per hour being dissipated by the radiator(from combined cooling and exhaust recovery). My convert program says that ammount of BTU is about 7.5KW. If his roid is true to form, it is burning about .125 Gallons per KW/hour or a little less, about .54 GPH at that load. With #2 at around 140,000 BTU/Gallon, he is consuming around 74,000 BTU of fuel and getting 25,584 back as heat. That is about 1/3 of the heat, when the rule of thirds tells me that he should be getting closer to 2/3. His high temp seems low, which is also hurting his efficiency IMO.
As for the shaking, that looks like a demo system to me. I don't think it is intended for use from a trailer, but I may be wrong.
Ron
