Author Topic: My first Lister up and running  (Read 13121 times)
oliver90owner
Re: My first Lister up and running
« Reply #15 on: November 10, 2008, 08:14:46 PM »
Regards, Tacho.  Most decent mutimeters have a frequency range.  Most plug in power meters have a frequency read out (Killawatt etc?).  So no dedicated tacho required is long as the generator is working, just set the output frequency to 50 or 60Hz as appropriate.
It might sometimes help if you give your location somewhere in the posts or in your profile.  Cambridge is in England.
Regards, RAB
Petersbpus
« Reply #16 on: November 12, 2008, 10:00:42 AM »
I always  thought Cambridge was in Massachusetts  ::)
Listeroid 6/1 in progress
Alllis Chalmers 60KW 3 ph
Changfaoid 12KW w/  auto shutdowns, modern AVR and panel
2nd Changfaoid 12KW Marine conversion w/ full auto shutdown and remote panel
Changfaoid 7.7 hp driving 5kw alternater /inverter,
other diesel gensets bought fixed and sold
sodbust
  • PressMaster
    • Oil press info and bio diesel use.
« Reply #17 on: November 23, 2008, 03:56:31 PM »
From what I know,, the ST can spin cw or ccw.. The brushes are up and down, and the cooling fan will move air each way.
sodbust
