A while back I put up a post about a missing compression stroke. Well today I went out to check it out and found that everything was just as it should be. I just was not getting any compression when I rolled it over slowly, but when I spun it up the compression stroke was there. I think its just that the rings are not seated in. So, I put in some fuel and bled the lines and kicked it over and it started right up! I still need to get the throttle assembly adjusted and get a tach so I can get it dialed in, but first smoke, what a great feeling.
