Author Topic: How long can you store wvo?  (Read 10616 times)
captfred
« on: September 27, 2008, 10:31:38 AM »
So how long can you store this stuff?
Got lots of oil readily available from multiple sources.
Got a ready supply of surplus 130 gal propane tanks I can pick up for 20 bucks ea., less in quantity. (55 gal drums are more expensive - go figure).
Got a surplus underground quansat hut (munitions bunker) to store it all in.
So, does anyone know how long you can store wvo without it going off (stinky, slimy or whatever that makes it unusable)?
Cheers, Fred
Combustor
  • Combustor
Re: How long can you store wvo?
« Reply #1 on: September 27, 2008, 12:08:59 PM »
        Fred, sounds like your lucky day just arrived! If the oil looks and smells good when you get it, provided you can settle out any free water and gunk, and store in clean sealed containers,(as in your bunker), it should be good for years. If containers are near full to exclude air, you should be fine.  Regards, Combustor.
biobill
« Reply #2 on: November 12, 2008, 01:14:26 AM »
Fred,
  I processed some a month ago that had been sitting in 5 gal pails w/lids for three years and it was fine. Water, crud, chicken parts, and french fries in the bottoms of the pails didn't seem to hurt anything and, being hermetrically sealed, may have still been edible ;D. The oil I decanted was clearer than what I usually get - probably from sitting so long. We don't have your temperate climate here. Temps range from -20 to 95F so YMMV. I've yet to see any "spoiled" or hardened oil that was kept in an opaque sealed container with minimal air space. Think linseed oil.     Bill
Off grid since 1990
