mobile_bob,
No, not ruffled my feathers
Someone else wears the dress!!
Did you read Listerboy's posting? I hope forks didn't miss it.
I would be in agreement about the wedge but that might also be a little time dependent as well. Don't know.
I kept away from timing 'cos I know not what the fuel might actually be. Might even be late and still burning stronly as it exits the (pre) combustion chamber.
Piston cooling? Not a clue as to whether it is needed on a lister or not. Will all help as long as there is not too much oil being flung onto the cylinders.
Listers and listeroids - many are not even comparable with a proper Lister by the sounds of things.
top shells being beaten to deathProbably got that 3 thou+ clearance a lot seem to think is correct. Maybe too little tin etc in the white metal used by the Indians.
hollow dipperInclined to agree that might be an improvement. No need to try it on mine though. Works OK. Proper Lister.
oil level sufficientYou can now see how the lube delivery works from the schematic. Simple and idiot proof (nearly).
We can all disagree with the way things are done but what might wrankle is the bland assumption that everything that was right then is still the only right answer now. Often it still is perfectly OK - and much less likely to fail than the modern alternative. It would certainly have been much better by now if the indians had not simply made a sub-standard copy and modified variants of the original. Their good copies might have surpassed the originals in
quality and longevity (with modern attributes), but unfortunately that is not the case.
Regards, RAB
