Author Topic: Red Hot  (Read 48139 times)
lendusaquid
Re: Red Hot
« Reply #30 on: September 29, 2008, 06:19:48 PM »
Using single grade non detergent by the way.New Indian piston and rings.New dry liner in an old block.I did give the piston to the company fitting the liner.
compig
Re: Red Hot
« Reply #31 on: September 29, 2008, 07:13:18 PM »
Hasn't that point just been made ?
Sorry for being a bit slow ..... but the point was made that 'non detergent' is better than 'detergent'. The part that I am concerned about is that one product is specifically produced for diesel engines and the other product is for things like lawnmowers (gasoline). I don't know what difference there is if the label says 'diesel' so I just want to clarify.
Jens
Lister A
Onan W3S Genny
Petter A1
Villiers C45 industrial
compig
Re: Red Hot
« Reply #32 on: September 29, 2008, 07:21:32 PM »
Jens
You need a non detergent , mono grade. I did some checking around earlier and most modern mono grade Diesel service oil is either low or full detergent. However , non detergent mono grade Diesel is available but you may have to order from a lubricant specialist. Thinking aloud though , normally the main reason for using a Diesel quality oil in a Diesel engine is that they pollute the lubricating oil with diesel fuel and diesel service oil has additives to neutralise the effects of this. However , if the engine is running on veg oil or WMO etc this wouldn't be a problem so gas engine oil should be fine.
Lister A
Onan W3S Genny
Petter A1
rcavictim
Running without oil
« Reply #33 on: September 29, 2008, 07:26:34 PM »
Jens
Jens,
I'm not as fast as I used to be either and worrying doesn't help....  so don't worry about it.  :D
As far as 'diesel formula' lube oil I believe there is an additive package that allows the oil to tolerate much more carbon in suspension.  It may also have a stronger EP formulation to maintain film under the increased rod bearing pressures seen from higher compression of a diesel over a gas engine.
BTW, since I learned the truth about multigrade oil I have switched from using the recommended 15W40 in the 4-cyl VW diesel Rabbit engine in my DIY power plant in preference to straight SAE 30W diesel lube oil.  I buy it in 20 litre pails from Wall Mart.  I use the same oil in my Jiang Dong 175A and the mighty Changfa 1115.
That straight weight 30 (Wall Marts recycled cheap brand with the green label) must be some good oil because my 1.5L VW, 9 kW plant ingested all of it's own lube oil through the valve cover breather after I made a plumbing change earlier this summer while at a 4 kW constant load at 1800 RPM and ran for at least 30 minutes with zero oil pressure after the stage of sucking foam for an unknown period of time.  I have no low oil pressure shutdown and the engine was unattended at the time. OOPS!!!!  After installing a DIY oil trap in the breather line and an oil and filter change the engine still runs like a top and does not use any crankcase oil, nor does it smoke.  I note a very slight increase in tappet noise since the event. No low end noise whatsoever.  I've still got 50 PSI hot oil pressure at 1800 RPM and 110 PSI cold.   Talk about dodging a bullet!
-Changfa 1115
-Want Lister 6/1
compig
Re: Red Hot
« Reply #34 on: September 29, 2008, 07:29:38 PM »
I'm a bike nut to !!  Just in the process of restoring my '52 Vincent Rapide. Have quite a few other's tho , my taste's are quite eclectic ! From CZ's to Vincent !!  Ducati's are my main passion though , particularly the 60's and 70's bevel cam singles. One of my favourite riding experiences was my 1922 Triumph 550 SD , everything was manual , handchange 3 speed box , etc , compression braking was better than the actual brakes !!  One thing I really liked was the total loss oil system , one pump every 10 miles or so depending on engine load !! Gave u a real sense of being part of the machine. Thing is , I sold it in a fit of mental aberration when someone offered me silly money for it !! Arrrrgh !! So , now I keep looking for the holy grail of Vintage Triumphs , the Ricardo 4 valve !!  Thing is , trying to find one under £10k is looking impossible.
ooer missus, original 900ss desmo's were my ride of choice back in the day, though a couple of years ago I ended up with a full raceco / termignoni guzzi 1100 sport, the proper red one with carbs...  had to sell it, that or kiss my licence bye bye... bought that off dr john, of norton single tuning fame.
current sled is an old TR1 which has been modified a wee bit, as a sort of homage to the old vinnies (even has HRD footrests which sends gentleman vinni owners apoplectic) some pics on page 2 of the gallery
https://surfbaud.dyndns.org/sites/photo%20album/index.php?twg_album=bikes&twg_offset=0
usual warning, home web server on cable modem so not too snappy, not all my bikes by a long shot btw.
worst selling mistakes I ever made was a 120 panther and an old sidevalve bsa v twin that I never actually rode, but swapped for a running jampot norton.
never actually run a vinnie myself, but for a couple of years was forever bumping into the bowden boy at various locations through europe, riding his dad's old prince, dad was chairman of the vmcc back then, but used to borrow a mates comet once in a while.
as for the ricardo...
http://www.yesterdays.nl/triumph-1923-ricardo-p-394.html
way too much for a trumpet
sure they'd take the vinnie off your hands... vbg
Beautiful example and I'd love it , but , as you say that price is dreamland !!  Panther 120 , the Lister of the bike world !!   Had a 900SS bevel Ducati , dropped it in France and although it was rideable there was enough damage for it to be written off. I did a deal with the insurance company , bought the salvage for a song and built myself an NCR rep !!  Then I had another mental abberation , sold it and bought a Honda CB1100RC !!  I want the NCR back !!  Strange you mention a V Twin BSA , I would also love a Y13 ?  I think thats the 750 OHV V Twin , but they fetch silly money now.
Lister A
Onan W3S Genny
Petter A1
rmchambers
Re: Red Hot (rides)
« Reply #35 on: September 29, 2008, 09:35:49 PM »
My dad used to race a BSA Gold Star back in the day (when all this were fields), I've only ever seen one in real life once and it was a nice piece of kit.  Many's the time he wished he didn't sell it (and me too cos I'd have inherited it sooner or later).
He also had a ducati with a sidecar that he used for courting my mum - that would be unheard of nowadays.
compig
Re: Red Hot
« Reply #36 on: September 29, 2008, 10:21:39 PM »
Goldies are indeed iconic machines. I would love a DBD34 RRT2 Clubman , also a Velocette Venom Thruxton with the full fairing , but , I wanted my Vincent Rapide more and my wallet doesn't equal my desires !!
Lister A
Onan W3S Genny
Petter A1
listeroil
Re: Red Hot
« Reply #37 on: September 29, 2008, 11:56:05 PM »
I have produced a couple of pages from the 1953  6/1 Lister manual which tells you which oil to use. Lister 100% state use heavy duty detergent oil because of the higher sulphur content in the diesel fuel are they wrong. I dont think so. This information remained the same in all the later manuals for the CS engine right up to the latest genuine lister manual I own which was printed in 1982.
On my own setup a 8/1 engined startomatic I use HD30 diesel engine oil and a full flow filter and change the oil every 2 months.
[/img]
[/img]
Mick
Re: Red Hot
« Reply #38 on: September 30, 2008, 01:13:20 AM »
I think Jens is going to need to share his crow recipe.  ;)
    • Doug's Petteroid Stuff
Re: Running without oil
« Reply #39 on: September 30, 2008, 02:04:46 AM »
Jens
Jens,
You never used that low oil presure switch I sent you Rob?
Stan
Re: Red Hot
« Reply #40 on: September 30, 2008, 02:32:14 AM »
Listeroil......The quote from the Lister manual (mine is the same) states that the "filters" must receive frequent attention during this initial period."
I don't see any deviation from the "filtered machines use detergent oil, non-filtered machines use non detergent oil" philosophy.
The logic is unassailable, detergent oil keeps crap in suspension, non detergent oil lets the crap settle out in the sump.
My 6/1 Lister has a sump (which was full of crap so that part of the equations works) but doesn't have any filters (the strainer isn't called a filter by Lister, nor is it).  What's the problem with understanding this simple bit of logic?
If your Lister(oid) has a filter, use detergent oil.  If it doesn't have a filter, use non-detergent oil.  Seems simple enough to understand!
Stan
compig
Re: Red Hot
« Reply #41 on: September 30, 2008, 10:23:51 AM »
Can't argue with that !!!
Lister A
Onan W3S Genny
Petter A1
rcavictim
« Reply #42 on: September 30, 2008, 12:27:38 PM »
Been way too busy to think about it.  Fact is the generator is useable in it's present form with no control panel yet made and just a clip lead to the battery as a on-off switch from the fuel solenoid in the IP.  A second 'clip lead' is the glow plug rail and a third clip lead is for the starter.  When I built it, once I got to that point I had to proceed to the next project. With the demands on my time round-tuits are very precious.  I try to run a large physical plant here and those 200 guys that are supposed to show up for work every day never do, so I have to do everything myself.  As a result stuff gets neglected a lot.  I know it's my own responsibility and if the engine dies an early death it is my own fault but I'm clearly a bit overwhelmed and way overloaded these daze.
-Changfa 1115
-Want Lister 6/1
oliver90owner
Re: Red Hot
« Reply #43 on: October 02, 2008, 12:00:33 AM »
I don't see any deviation from using improved technology.  Perhaps somebody can supply me with the oil filter part numbers from the appropriate parts manual?
You are quite right, but not completely.  The 'crap' kept in suspension is regarded as much, much less harmful (even to the point of being harmless) than if it were in suspension in a non detergent oil.  The size range is completely different (probably by several orders of magnitude).  Any large 'crap' will settle from a detergent oil just as it does in a non detergent oil.
This 'crap' as you call it is not filtered out in any modern engine by the normal full flow filter.  A full flow filter able to do that would present such a high pressure drop as to be pretty well useless and, furthermore, would block so quickly that the bypass valve in most filters would be operational long before the normal filter change.  Modern engines also circulate much less service volume than an older vintage design ( more flow, therefore much higher turnover or faster circulation of the oil).  Sludge, as you call it, was also produced in petrol engines as well.  I have had several where the oil slinger was running in a narrow 'groove of lube' without apparent harm for a long time.  They were built to last even with abuse!!
The 'crap' that is collected by a full flow filter is several microns or more (probably greater than 10microns in many applications).  That is the sizes which damage engines and those will still settle in the sump - just not so much of it.  To say nothing settles if a detergent oil is used is utter rubbish.  The sub-micron colloidal suspended particles just keep circulating.  The heavy particles will settle.  The large oil capacity and relatively low circulation speed lends itself to that.
Now, a  Lendusaquid's Lister may have one or two (or perhaps more)  problems. First the amount of lube thrown up to the  underside of the piston crown may be so little that it is evaporated or charred, both leaving a deposit that is not wanted.  Second the piston may be getting hotter than anticipated when using veggie as fuel.  Maybe it is thinner at the crown than a proper original Lister piston (I wouldn't be surprised).  It certainly would not need to get anywhere near 1000degrees Celsius or Fahrenheit to degrade oil, and nobody on this thread has suggested it gets that hot.
Now lets get this straight.  There will be circulating sludge before it actually settles out in the sump.  It will be less, but it will be there.  The piston will be running at near maximum temperature (whatever that might be) if the engine running at maximum power for long periods.  OK the engine is designed for that (and it should not seriously affect longevity).  If the oil is charring (due to low quality oil?) change it.  If it is due to 'higher than normal' temperatures, change the oil or the conditions which have caused that increased temperature.  If it is lack of oil flow to that area then that obvioudsly needs investigation and improvement.  The small end bearing relies on that splash lubrication as well.
If the engine is tight, that may mean the tolerances between piston and bore are less than design, or lubrication is marginal, or perhaps even the ring gaps are marginal, or parts are running too hot.
These are all possibilities/suggestions, just as trying a synthetic oil - which will be more tolerant of higher temperatures - for instance turbos do operate at elevated temperatures and the bearings have been 'cooked' in the past due to poor quality lubricants or even with good quality lubricants and operators not allowing time for the heat to be dissipated before removing the oil supply (turning off engine), or simply leaving the thing spinning at huge rpms with no oil flow.
There is no reason to think that oil changes should be lengthened by using higher quality oil.  This is often related to the combustion products which invariably contaminate the oil, but also operating conditions, such as temperature, stop/start cycles etc. all play a part.  Lendusaquid may well be using a vey low sulphur fuel and that might well influence the oil change interval.
A no brainer really.  Follow the manufacturers instructions.  Don't make up your own rules unless you are prepared to stand by the consequences.  A full-flow filter has absolutely nothing to do with it.  It does not filter out suspended coloidal particles.  They will pass straight through the filter medium.  That is how they are supposed to work.  How many people have to be told  how many times before this sinks in! A full flow filter does not collect colloidal suspended matter from a detergent oil.  It only collects LARGE particles which cause wear in the engine.
On a similar note, there is also utter rubbish talked on this board about the clearances for big end bearings in Lister engines.  The manual states absolutely and unambiguously 'less than 3 thou.', yet there are a stubborn minority who insist 3 thou is what it should be set to.  The manual is clear.  The big end clearance should not be set at more than 3 thou. and almost 3 thou less is perfectly adequate and is what should be aimed for - free, with no binding.   Yes the engine will tolerate more, but the manufacturer gives that value for maximum service.  If the manual says detergent it means it.  If they were wrong, there would have been inumerable claims for broken engines.
There are no crankshaft oil seals,  as such, on a Lister 6/1.  It relies on negative pressure in the crankcase to prevent oil seepage.  This may not be the case with TRBs.  Any neoprene or other manufactured seals may expand/contract depending on the lubricant.  That is well known - lots of engines became leaky when changed to synthetics before the seal technology advanced to keep up with the different lubes.  Not a problem now.  Same with detergent or non detergent. Some think that detergent must mean multigrade.  It most certainly does not.
A mono-grade oil will only have it's rated viscosity when hot.  It will be much thicker when cold.  The additive package in multigrade oils is there simply to improve the viscosity at cold temperatures (the W bit of the spec) to improve lubrication (highest wear rate in an engine happens at start-up from cold, before the engine tolerances have settled, and reduced lubrication due to the oil flow (or not) and characteristics , as the case may be and due to cylinder 'wash' from unburned fuel.  Viscosity is very much temperature related.
Regards to those who actually read the small print, RAB
Re: Red Hot
« Reply #44 on: October 02, 2008, 01:29:20 AM »
RAB:
sorry i missed your earlier responce to my post, my puter took a dump and is in the shop
and therefore i am using my daughters laptop and missed a day or two.
anyway, i am sorry i blew your dress up around your neck :)
i will defer to those with vastly more experience with the original listers, and maybe that includes you on
certain points,,, however
i will not simply roll over and play dead when it comes to a few points,
one being the need for oil splash to cool the piston, this is a concern with every internal combustion engine that
was ever made (at least the ones that were successful)
the original poster talked of the engine becoming tighter after it had been run and voiced concern whether there was
sufficient piston to bore clearance.
i think we can assume that the oem made the bore near perfect as well as the piston being properly sized as well, so
if it is getting tight when hot is a good indication that there is some fault with cooling allowing the piston to overgrow the
oem clearance spec.
i am not suggesting that this is the only possible reason for the engine getting tighter, only mentioned one area that might be
investigated to eliminate that possible cause. surely there are other area's that should be checked first, things like timeing issues, injector spray, fuel type etc etc.
as for splash lube, yes i know it works on many engines, and has been successful, but
to my knowlege the method that lister used was somewhat unique as it relates to big end oiling.
yes the system worked well with the oem setup, which includes the oils they spec'd, the fuels they spec'd, the load
that it was rated for, "and" the original metallurgy of the big end brgs (metallurgy which has changed over the years)
the primary reason i don't like the oem oiling system for the big end is based on the experience of those running listeroids
which use the same oem design, but modern brgs metallurgy, modern oils, and fuels,, and it does not work as it did on the originals!
i have seen many examples of the top shells being beaten to death and needing replacment far sooner than i would expect
the oem lister ever required.
if you were to do a bit of study on proper big end oiling, the need for establishing a hyd wedge (and maintaining it) it becomes
apparent that those two top feed holes and their accompanied grooves destroy the wedge that is formed which in turn shortens
the brg life.
many years ago the cummins small cam engines used to use a top hole to provide oil through a rifling to the wrist pin, those
brg needed replacement every 75k miles (if english origin) or 150k miles (if japanese origin). cummins found that the placement of this hole was in line with the peak cylinder pressure and caused a breakdown of the hydraulic wedge,, effectively beating the top shell to the point of delamintation of the brg. In the late 70's they changed the design and moved the rifle hole offset about 30 degrees with the result being brgs that lasted twice as long with no other changes being made. later they found in the big cam1 or maybe bigcam2 engines the change in the hole location allowed them to reduce the oil pressure from 60psi hot to ~30psi hot without loss of brg longevity.
engineering text goes into much detail on not putting any holes in the top shell near the top where cylinder pressure is high, and not to put any grooves in the brg at all.
i know this works, i have seen it. i also know of a supplier in canada that special ordered some brgs for his engines that had no holes or grooves and installed them with a hollow dipper. the result has been a dramatically improvment in the longevity of his engines and he runs them very hard in continuous duty running waste veggie oil.
as for piston cooling, there must be some oil being thrown up under the piston to aid in cooling, maybe not much for a 3/1 and maybe even not much for a 6/1 on moderate loads,, but
if he has some coking under the head of the piston he has a problem, and therefore he needs to explore and find the reason why
this is happening. if there is sufficient oil up there it will cool the piston and not coke, even if he is running advanced timing, overfueling or running some hot fuel mix. certainly if the timeing is off, running under heavy loads, hot fuel, etc. he will need more oil splash to cool the piston.
i only offered one possible area to look into that being is the oil level sufficient to be picked up and sprayed up under the piston,
i did not suggest this as the only possible answer, just simply one that can easily be checked. i would not want to hear back later that
the engine was made up of various parts (unknown to him) that might not be as you or i suspect, and therefore be lower on oil than it should be. i think i mentioned earlier about a friend with a twin petteroid that filled the new engine to the full mark, and later found that the engine was about 2 quarts low (after removing the side cover and finding the oil pump pickup tube only partially submerged) because the dipstick was from another type of petter or was marked wrong.
sometimes it is the stupid details we just assume to be correct that come back to cause us the most grief.
to conclude
if i had an original lister, and original lister brgs, running a non detergent oil of the proper weight i like you would just run it.
however here in the states original listers are like finding a 53 corvette with 100 original miles locked in some old ladies barn!
we gotta live with listeroids and as such have to accept that there are improvments that can and in my opinion should be done
to improve the longevity of the engine.
also i have been around for a very long time and know a thing or two about diesel engines in general, and proper engineering practice in particular.
btw,, i still don't like the oem tophole fed big end brg design, even if it has proven sucessful!
as i am sure there are things you don't like about some other engine design.
